Can someone please tell me why I'm now getting these errors with Promise Connect on startup?
This just started happening, I can no longer access any projects in Promise Connect. Once these prompts have finished popping up it just sits there saying 'please wait while loading...'. Refer to snapshots below.
Kind Regards
Kane
  • Hi Kane,
    you can try the below suggested Wiki Links for the 1st and 2nd Error Message respectively can let us know if they help with the issue you are facing.
    For the above Error Message follow the below Wiki Link and check if it helps.
    Kindly let us know if the above suggestions help with the issue you are facing.
    Satish Saptasagar
