HiIm trying out Openplant Support Engineer.I want to create my own catalog of pipe attachment. It should look the same as a included support in the catalog. Only other parameters/measurements. How do I do that?
Can I copy/export a included catalog somehow and use "Catalog Loader" to import it back in?How do I export the catalog data?Or do I need to use the "Component Builder" and create a completly new component modify scripts and stuff like that?
Hi Jojje,
Thank you for posting query in Bentley Plant Forum.
One needs to follow a specific procedure to create a new catalog. If one wants to add a completely new component in the catalog then he must have a python script for component creation and placement.
Steps to Accomplish:
1. Import the Python script. (Only in case of a completely new component)
2. Create a new template. (Only in case of a completely new component)
3. Build the Component using the template.
4. Add dimensions of the component and save.
This should help you create new catalogs.
Please refer the wiki articles on OPSE for more help.
OpenPlant Support Engineering v8i OpenPlant Support Engineering OpenPlant Support Engineering (OPSE) is an application which will provide complex design and Modeling of Support for Piping, Structural, Electrical and HVAC Components.… Last edited over 3 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
Regards | Swapnil Joshi
Ok. Thanks.After a bit of investigating I acctually realize that I want to create a "BasicShapes.ClampedTeeShoe".
What does "add a completely new component" actually mean? If I want to create a BasicShape for example...do I still need to create the script simply so that I get the parameters to be able to define them in the new template?
Thank you for the response. What I meant by "add a completely new component" is that if you want to add an element whose template is not present in the existing Templates.
Thanks SwapnilI think I understood how this works.
In the "OPSE Content Development Manual" help file ive found a example. However its just in a picture and I will likely make a misprint or something.Where can I find a example in textform?
