Anyone else had issues running Acadpan in SS6 PID? Just can't get the middle button pan to work in anything other than an x-button.
Rahul Kumar
Not sure why you need the pic. The issue is that Acadpan will work in AECOsim as it's set, but not in OPPID.
The mdl is loading fine as far as I can tell.
Thanks Bear, as I am not fully aware about this feature, Hence requested, so that I could test and check if all holds good.
