While placing the auto plant component following error is appearing
Error:at_CADCurrObjectSet_addToDrawing: Execution error.nil
After Picking the point to place, the above error is appearing
1) tried (at_pipingsystem_setvariable "DRAW_MODE" "3D") in the drawing , saved , reopened2) Checked the "DRAWING MODE" of both piping and the equipment , both are having the 3D
still the problem is occurring
Problem :is component specific in all the specifications
i have attached the snap shot for the reference, please help me on this
Thanks & Regards,
Govardhan chindam
Hello Govardhan,
Thanks for posting your question.
Could you please check with default spec. If Outbox spec working fine. then problem with your spec.
This error generally occures when use wrong data types in spec.
Please compare your spec with outbox spec. and let me know the result.
Looking forward to you reply.
Abhijit Bute
