Exacting the Bill of Material or Isometrics using the Advanced selection options is failing /error
Hello all ,
Exacting the Bill of Material or Isometrics using the "Advanced selection in the options" in the Autoplant  is failing /error
when i am doing through manual selection its working
Problem: But when i use the Advanced selection for any process its getting failed by poping following error
Clue: i found some components have no system ID's( NO SPEC RECORD)  using the SPEC_SCAN ,
I tried updating the components(in spec_scan), its not working
is this could be problem ?
Please help on this
