I am signed in to CONNECT but receive "This session of OpenPlant Isometrics Manager CONNECT Edition will timeout in 2 minutes." when trying to edit seed file. CONNECTION client is running and signed in, also the seed editor itself displays that I am signed in. How do I avoid being kicked out of the seed editor tool?
Edit: Thought the CONNECTION center update fixed it- nope. Using latest CONNECTION center 10.00.15.12 does not resolve this issue.
Hello Jonathan,
Thanks posting your question.
Could you please provide me OpenPLANT Isometrics Manager version?
Abhijit Bute
Hi Abhijit, I'm using OPIM 10.4.0.30
I have provided this information 8 days ago. Any update on this?
Hi Jonathan,
This issue will be repaired in the upcoming update 5 build of OPIM. There is no workaround for update 4
HTH, Frank
Answer Verified By: jonathan.horvat
Frank,
Thank you!
-Jonathan
