During modelling I accidentally changed the weld from unlocked to locked. When I try to chance it back to unlocked I'm getting error message Property Value Is Not Valid and Locked value stays. I'm not even able to delete the weld from my model. How can I fix this?
I can't find the post right now, but I've read sometime ago a similar question. The solution was to unlock it using plain microstation, that is open the model in MS and unlock the component.
Edgar
Answer Verified By: Tuomas Takkinen
Thank you Edgar, this one worked for me.
BR
Tuomas
