We are using AutoPLANT 10.0.0.36 CE on Windows 10 & Windows 7, and have noticed that it still comes with a rather dated tool with controls from maybe the mid-90's called "Autoplant class editor," which is apparently of no use anymore- but not the "Bentley Class Editor" which is necessary for repairing the schemas being used now but which are still dysfunctional in their out-of-box state (e.g. Cannot run an isometric if it contains lug bolt without fixing schema to include it). When will this be corrected, and where can the Bentley Class Editor be downloaded separately? I searched in the software downloads area but got 0 results. If this tool was left out intentionally, I would expect it to be available as an independent download. Please advise.
Jonathan
Hello Jonathan,
Thank you for posting your query on Bentley Communities. We have forwarded your query to the concerned personnel who will contact you at the earliest.
Devendra Warke
Bentley Systems
Thank you, Devendra! I received the download link.
