I have been struggling with the error below off and on for a couple of weeks.
OPM V8i SS6 08.11.11.316
PW CE 10.00.03.167
64 Bit Access Database Engine
Data Manager V8i SS8
I click OK, the model continues to open however no line sizes are available for selection.
**EDIT**
Randomly the Project Wise login appears while still in a session of OP. I log in, the model exits and then am forced to free it.
If anyone needs any further information please advise.
Subject file attached
1537.Piping.dgn
Hello Jason
Thanks for posting your concern on Bentley forum.Can you please check the same with local workspace of OpenPlant Modeler, are you getting same error message? What's the version of MS-office that you are using at your end?In case of managed environment, please try to switch to some default spec & notice that are you able to load nominal diameter list or not.ThanksRegards | Deepak Singh
