I'm working on a electrical room layout which is rotated from default coordinate system and is not perpendicular to it, that means that cable routings and equipment tags are being created using a different coordinate system from the layout.
Hi Rodrigo,You can try defining the new ACS according to your requirement and then set it to global and you can then place the components according to the new ACS.You can define ACS from Drawing >> Drawing Aid >> Define ACS under ACS for CONNECT.And for V8i you can access ACS referring the details from below image,And to set the ACS to global you can refer the below Wiki Link,
