Running OPM CE update 4, we find that Bolts gaskets and 'obstruction volumes' have graphic attribute set to Primary.
With reference to v8i post
https://communities.bentley.com/products/plant/f/autoplant-axsys-openplant-plantwise-forum/124118/opm---assign-gaskets-and-bolts-to-a-different-level/377001#377001
Are we missing anything?
Hi Peter,
Thanks to notify here.
This is known issue. May we please request you to log service request for the same, so that we could update the defect and prioritize the issue?
HTH,
Rahul Kumar
Hello Peter,
Regarding this concern we have logged Defect 935020 against OpenPlant Modeler CONNECT Edition Update 5. However we have tested this in upcoming version of OpenPlant Modeler Update 6 & now clicking off construction from view attributes turns off the construction elements. Refer images below.
Construction ONConstruction OFF
ThanksRegards | Deepak Singh
