Hello Everyone,
I have required single pipe length for BOM report including pipe bend length in it.
i have tried a lot but not get the required value.
will you please help where i do correction to get required value?
reference screen shots are attached.
Thanks You in advance!
Vishal
Hi Vishal,
In v8i version, you need to customize crystal report to achieve this as both has different classes PIPE & PIPE_BEND. However if you like to extract in xls sheet you could use pivot table to consolidate it.
See below where qty has been described like this.
How to Generate Consolidated BOM for Components using Pivot Table Applies To Product(s): OpenPlant Reporting Version(s): 08.11.09.564 (SS5) | 08.11.11.87 (SS6) Environment: Windows 7/8.1/10 (64 bit) Area: Reports Subarea: Piping… Last edited over 7 years ago in OpenPlant | AutoPLANT > OpenPlant | AutoPLANT Wiki
We have addresses this issue in newer CONNECT Edition version where user can extract the records as desired.
HTH,
Rahul Kumar
Hi Rahul,
Thanks for your quick reply!
will you please tell me a short procedure to customizing the crystal report to achieved these values?
bcs i tried revised crystal report but failed to get this value
Customization requires Crystal report license which is suppose to be with Bentley Professional services team. We will inquire internally with team and any quick assistance may be provided here. Or possible someone could assist you here.
