Autocad 2016 SP1 U2, Autoplant V8i SS6 08.11.13.245, OPIM 08.11.11.285
When adding a note in Autoplant Piping (Piping menu, Misc. Attachments, Comment), there appear to be two issues:
1. After a comment has been created, if the enclosure type is changed on the comment, the new enclosure type is not retained.
2. The enclosure type is passed through as None in OPIM, resulting in a Component_Type project of NOTE_NONE. Since this property is used to drive the enclosure cell name in the Variable Shape Note in OPIM, this results in no enclosure in isometric drawings. The PROPERTY attribute and NOTE_TYPE attribute in OPIM also do not reflect the selected enclosure type for the note.
This happens right from the default/sample MMETRIC project/OPIM configs. How do we fix these issues?
Hello Chris,
Could you please provide me AutoPLANT Modeler and OpenPlant Isometrics Manager version?
Abhijit Bute
Thanks for you reply. This issue has been reported in Defect # 760633 and fixed in AutoPLANT Modeler SS8 Refresh 3 version 08.11.14.124 version, which is compatible with AutoCAD 2016.
Please find below link for Readme file of AutoPLANT Modeler SS8 refresh3 version
Hope this Helps. Looking forward to your reply.
