Hi All,
How do I create a basic cutting plane:
E.G. I have a building with cable trays inside, now I want to print the top view. In order to see the cable trays i need to cut below the roof.
Previously in the AutoCAD world, I went into the layout area, created a -VPORTS and then with 3dclip moved the clipping plane around, what is the BRCM equivalent to this procedure?
Thanks in advance
Philipp
Hi Philipp,To create a basic cutting plane you can use section clip tools available in BRCM.
Go in View Toolbar >>Clip Volume>>Section Clip Tools.
The Section Clip Tool will clip the schematic along a section.
Through the section line , the section to be clipped can be moved.Hope this was helpful.Regards,Lalitesh Vaidyar
Answer Verified By: Philipp Holenstein
