Here is the process:
I right click on the project I want to back up:
Then I get the following error messages:
Error message 1:
The next error message pops up when I click "OK":
After I click "OK" on this error message, the whole back up process stops.
Please help.
Hi Edmund,You need uncheck 'language phrases used' to successfully back up your project drawing.Languages phrases are used if foreign language text phrase is to be used in a drawing.Hope this helps.
I'm still getting the same errors.
In the error message is states that the file is being "used by another process". What other process could be using that file?
Hi Edmund,Is the issue you are facing after Promis.e was closed suddenly ? You can try the below Wiki Link as a suggestion and check if it helps with the concern.
Hope the above details help.
Regards,Satish Saptasagar
Hi Edmund, Can't say about the error message or the process which is using the said file. It needs investigation.Will update you accordingly.Instead, for AutoCAD compatible drawing file creation, you can try exporting the project drawing to .dwg format which is AutoCAD compatible. Go to File>>Export>>Select DGN,DWG,DXF option.
Select the location and you can also select the file format in which you wish to save the project drawing. Hope this helps.
