how to modify "Field wiring report" report to have each cable start on new page?
Regards, Wojtek
Hi Wojtek,
Can you please clarify my understanding, in Field Wiring Report your requirement is each cable that is present in existing project should represent in new page.
Example:-
Please can you provide some sample file to understand your requirement.
Currently I cannot see any option to directly do the same, Can you try contacting Bentley Professional Services for the same.
As a Work Around you can use Filters like Installation, Location and other to generate the reports according to the requirement.
Regards,Satish Saptasagar
Hi Satish,
that workaround I am currently using (generate separate PDF for each cable and then merge them to one file).
But in the meantime I have found the solution. It's as easy as changing one setting in GroupFooter - and force page break after each group (one group is one cable in that report).
Best regards, Wojtek
SW: Promis.e 08.11.13.96/23.00.00.46
Answer Verified By: Satish Saptasagar
