When I was trying to open wiring manager following error message pop-up
Then I followed steps to resolve the above error,
1) So I open and checked the following status.
2) I also tried following to avoid the above error.
Another error, when trying to insert the symbol, following error message pop-up
Then restart the system, PC, SQL server. But still, error not resolved.
Please help to resolve.
Hi Aditya, Can we have meeting regarding this concern. We need to look into your concern to see what is the problem.Regards,
Avanti Khandalkar
Hi Avanti
,After our discussion on various errors, Please inform us,
1. Which steps to be avoided in future to eliminate errors ?
2. Which steps to be followed in future for easy and proper working on Promis-e ?
3. What could be causes of those errors ?
Above instruction will help us to understand and upgrade our knowledge about software working.
Aditya Wankhede
Hi Aditya, You are getting this Error because of Corruption of ProjectOption .xml file. IN that ProjectOption.xml we find that there are Mode setting which might be cause Error . We are not sure why you have created different modes in past. Regards,
