Hi All,
What is the best way to draw cable trays vertically?
By default, they are horizontally in the cable tray router, and I know by pressing "S" or "F" you can flip them so they are vertically (my organizational standard).
However, is that the only way or is it possible to already preselect them in a vertical position?
Thanks in advance
& Regards
Philipp
Hi Philipp,For drawing cable trays vertically you can use Place Part tool available in Raceway Router.While Routing a cable tray, after placing a datapoint place part can be found in dialog box that is available during Routing.In Place Part tool the direction of the tray can be changed.The cable tray orientation can be changed by using the place part tool available during the Cable tray routing.Hope this helps.
Answer Verified By: Satish Saptasagar
Thank you for your reply, I meant more how to draw the whole tray routing horizontally.But that option is still very helfpul, thanks.
Also I assume for the Raceway Generator, it always converts the line in an horizontal tray and there is no option converting it to a vertical one?
