could you give me advice which option in cable list import BRCM is fo cable trefoil configuration?
thanks in advance
Hi Miroslav,For Trefoil / Triangular Cable Laying mentioned to be used you need to route the raceway with the Cable Laying Method selected to "Triangular". And after the cables are routed the cables raceway Triangular cable laying mentioned will have cable will have triangular formation.If you need an option in Cable List Import you need to select the Cable Laying Method in the configuration dialogRegards,Satish Saptasagar
many thanks.
rgeards
