Hi
In my opinion it is a problem that if I want to work with Promis.e I have to convert the ALG file into an RSALG file.
Will this be changed in future?
/Lennart
Hello Lennart, Can you please let me know what problem did you observe in RSALG file?
Avanti Khandalkar
Hi Avanti
i see two issues.
1. If I copy and convert the ALG into RSALG, the file will no longer be updated by the track engineers. I risk designing signals on a outdated track design.
I would be better if I designed directly on top of the live an updated ALG.
2. If I choose the copy solution described above, what happens with my signal design when evetually changing the an outdated RSALG wih a updated RSALG?
