we are using V8i SS8 . I need to know the Promise V8i keyboard shortcuts
Hi Elango,You can try using the Key mapping in Promis.e by selecting the Key according to the what is displayed on the screen. For an e.g you can refer the below image where for opening Catalog Manager you select "E" key on the keyboard and then select "1" for catalog manager the Key for function can be seen on the left side of the function.Hope the above suggestion helps.Regards,Satish Saptasagar
yes it works thanks
