I am unable to insert a cable and receive the following error:
This just started happening and I need this resolved ASAP.
I am currently running Bentley Substation CONNECT Update 3.
Thanks!
Hi Huskey,Are you facing the issue the issue while placing the cable on a particular equipment or for all the Equipment in a project ?Regards,Satish Saptasagar
Hi Huskey,Also can you let us the Sag Algorithm and the Parameter Value that your are entering for the Sag Calculation.Regards,Satish Saptasagar
Hi, Satish.
I am encountering the issue throughout all my projects. I have tried multiple part numbers, both client created and Bentley provided, and still encounter the issue. See below for screenshot of the parameter value:
Hi Huskey,Have you tried changing the Offset value for the Sag and check if you are able to place the cable, may be reduce the value and check if it help ?Also how far are the Equipment Hook Point for which you are placing the cable.Regards,Satish Saptasagar
