各位老师好,请帮我解决如下BRCM出立面图导出dwg问题。左侧图桥架的弯通丢失,有图是整个立面图,弯通部分线性乱,并且巨大。立面图导出DWG文件怎样解决?
Hi Yanzhe,For the issue you are facing using Export to DWG, you can try to change the options while using the Export to DWG tool.1.While using the Export to DWG tool, Click on Options.2.In the Options dialog that is displayed under General tab , Check the Use level Overrides Options and Preserve BRCM Settings.3.In the References tab Select the Merge To Cell options and Check Merge Visible Edges of 3D attachments.Hope this helps.
Answer Verified By: Lalitesh Vaidyar
