When do the modeling work, how to chage the background from a single color(white or black) to a graduated mode?
Hello ,
You can follow below steps to change the background color
1. Open required DGN file and click on files tab
2. Navigate to Setting and then file. and click on Color Table
3. In Color table settings Double-Click on the 'B' at bottom right corner. Modify Color Dialogue will open. Here you can Set the Background color as per the requirement . You can also manage color book if required.
Please do verify answer if that help regarding your concern.
Answer Verified By: Vikrant Kale
HI Kale,
Thanks for your reply.
We know the method as you said. This still only a single color backgorund.So this is not what we want.
Hello Long Jun Deng,
Have a look at video attached here you can find the steps to achieve the desired results.
Please let us know if that helps regarding your concern.
Thanks for your help.
One more question
In prostructure V8i we just use the background to set the graduated mode without the setting in the video.
Why prostructure CE have can not?
I have tested the same with BRCM, MicroStation and Prostructure, and its looks like Prostructure V8i specific function.
For more details regarding this you can visit following link
https://communities.bentley.com/products/prostructures/
