Cable Numbers
Hi All,
Does anyone have an idea when if i add a cable symbol to a wire, and automatic wire number my drawing, the program still numbers the wire, even though i have to omit the wire with a cable box ticked?
Thanks in Advance,
Adam Burbridge
  • Hi Adam,
    It seems that this issue has crept into promis-e 08.11.12.47. This has been issued to the developement department as bug #29154 with the following title:
    Cable conductors incorrectly assigned wire numbers with 'Omit Labels on Cables'
    For the moment I would suggest creating a wire layer for field cabling and when using automatic numbering avoid assigning numbers to this layer.
    I have also created a request (#29156) to allow wire numbres to be assigned with a 'don't assign to this layer ' option in addition to the current option of just assigning to a single layer.
    BR
    John.
    This is a test
