GSA Project Setup
I'm trying to set up a GIS Project with GSA to include about three hundred GIS objects/features. They each have an attribute table. There are no joins or relates. There are some, but not many, parent/child relationships. So I've gone through the help menu and experimented a bit. I suppose my first question is what is the best way to test the XFM object once defined in the schema? Do I need to create a user workspace and run that, import a feature? I don't know how to apply the schema to a feature or how it knows what shapefile to associate with what XFM feature.. how attributes carry over.. those types of things. I know I can chose the schema file on each feature in the Interoperability Menu, but clicking each one - one at a time - to assign the schema is no good.
Other than the help menu, is there a quick way to trial and error this? Or a book or guide I can read?
Thank you!
