I did not understand if the seed.dty file is to be copied in the same directory of the program or may be or can be copied in other directories (for example C:\Bentley_Project). In addision in my configuration variable is not present the MS_GEOCOODINATE_USERLIBRARIES VARIABLE and so I have create it. Neverthless, when start Bentley Map and open Select Coordinate system is not present custom library. What is the detailed procedure to resolve this point?
To add to Jerry's content, here is a short video I have done, adding the possibility to name it, instead of picking the file name.
screencast.com/.../oVoQWpCPlX3U
Sebastien Cote
