Is there a help document on how to bring BING maps into Bentley Map SS4?
We've been looking at a similar issue today Krister. Can you attach the file, or open a Service Request to help troubleshoot the problem?
I've been able to get Bing Maps to work (CONNECT U7) via Raster Manager, but not View Attributes. As we implement severe firewall restrictions (CONNECTION Client wouldn't even work), I've been working with our IT security folks to determine where the issues are. We *did* finally enable CONNECTION Client to function, and we began on working on the View Attributes issue, but then the holidays and other work have redirected my efforts. I had just "assumed" there were additional port issues with the View Attributes and it isn't a high enough priority at the time to warrant additional work. Interesting that it *may* not be an issue on our firewall but rather an issue with the application...
Bruce & Krister,
Were you successful displaying Bing Maps as a MicroStation Background?
Bing Map Background Requirements:
Have not pursued it further. Just tried again (View Attributes) and does not work. I AM logged into CONNECT Services and DO have a GCS active and did set the background to both street and aerial. No success.
Still no success for me. I will give it a try with CE 8 and get back.
/Krister
Owner consultant at Surell Consulting AB
