Hi BM group
The most dissapointed thing that Bentley Map has in it for now is the "special" element type that "locks" Standard Microstation to read the Bentley Map file with full rights not only "read only". Don´t understand me wrong; the element type is suberb in Bentley Map but the lack of interobility to the rest of the platform using dgn is under all critic.
so my question for the next generation of 64-bit Microstation is this:
The "special" Bentley Map elements, Are they fully supported in next generation of Microstation?
Best regards
Tom Lillhannus
Sebastien Cote
Hi Ben
I´ll send you an email as soon I have time to. Have to finnish my current projects first.
I don't understand well what you mean by "MS items".
Found this explanation by Jon Summers on communities:
Item Types
Item Types, new to MicroStation V8.21, are meta data that define data types. In other words, a schema. Item Types are not graphic elements; rather, they represent a MicroStation capability for storing structured alpha-numeric data (what Bentley Systems term 'business data').
http://communities.bentley.com/products/betas/microstation_early_access_program/f/343352/t/100088
//Tom
