Hi BM group
The most dissapointed thing that Bentley Map has in it for now is the "special" element type that "locks" Standard Microstation to read the Bentley Map file with full rights not only "read only". Don´t understand me wrong; the element type is suberb in Bentley Map but the lack of interobility to the rest of the platform using dgn is under all critic.
so my question for the next generation of 64-bit Microstation is this:
The "special" Bentley Map elements, Are they fully supported in next generation of Microstation?
Best regards
Tom Lillhannus
Hi Ben
Now 4 years gone and my question still reminds. Are there or is there going to be any changes in this issue?
//Tom
Hi Tom,
Lillhannus said:Are there or is there going to be any changes in this issue?
as Ben wrote 4 years ago and as Bentley Map CONNECT Edition was implemented, there is no change in used data structures, so there are still XFM objects with metadata defined in external configuration created by Geospatial Administrator. Consequently it means the situation has not changed.
Your original question was about "full support in MicroStation", which I don't understand. What does it mean the full support when not original (authoring) application is not available and also not project metadata can be accessed?
As far I as I know the situation is the same with Bentley Map CE and AECOsim BD CE (not sure about OpenRoads Designer): When the file is opened in a plain MicroStation, only geometry is available and the object properties are hidden. The difference between BM and ABD is that BM locks its elements, so they cannot be corrupted in MicroStation.
Jan
