Hello
I have geographic data, that are stored in Oracle XE 11g (SRID 25832).
There is no problem to query and delete features. But, when I try to create or update an feature, I get this error "Error Inserting Feature (class: TEST_BUILDING, id: 28)
Invalid geometry for table TEST.BUILDING, column SDO_GEOMETRY.54668
ORA-54668: a 2D SRID cannot be used with a 3D geometry
Irreparably invalid geometry."
The problem is that SRID’s do not match.
Is there an easy way around this problem?
Answer Verified By: Sebastien Lefrancois
