Hi
Since all our CAD production is done with XFM in Bentley Map, we need to configurate PowerCivil to always activate Bentley Map on start up.
So what is the name and the setting of the appropriate configuration variable ? I sure there is such a configuration variable :-)
Erik Wirring
LE34
Denmark
Sebastien Cote
There is currently no variable that will allow Bentley Map to automatically activate when launching PowerCivil for Denmark. If you have Bentley Map licenses available, you can create a workspace in the Geospatial Administator that will launch Bentely Map when loaded. Loading Bentley Map this way, however, will report license usages. Opening Bentley Map inside PowerCivil using the Tools>Activate Map does not report license usages.
Answer Verified By: wirring
