I was asking an US organisation for US SDSFIE 3.0 data model files for Bentley map and got an answer....."not possible".
Is there someone that can confirm there is no more support for Bentley Map within the SDSFIE org.
Unknown said:We do support File Geodatabases in Map SS4 in read/write mode. Since you may be getting a file Geodatabase from the client, then you can set up your own Schema to work with their data.
Hello to all,
helping me.
I'm very excited and glad to read that. Great!
What Map SS4 licenses in detail and do I need ESRI licenses, too?
Frank
Hello Frank, No Esri license needs to use Esri File GeoDatabase in Bentley Map Ss4.
Enjoy it !
Sebastien
Hi sebastien, Bentley Map SS4 or Bentley Map Enterprise SS4 ?
Better: What 8-digit version?
Hello Frank,
In the last official Commercial Release Bentley Map V8i Ss4 08.11.09.503
This function is available in all Editions of Bentley Map:
I hope that helps,
