We have a map feature with the attributes stored in an msascess tablelinked by entity/mslink.
Additional attributes are required by this feature so the existing recordswill have to be migrated to a new table and the new fields added.
Any suggestions how this can be done in Map?
Miro
Being in technical support group, I would try the first option if possible. Th reason is we try to stay away of manual .xml edition.
Sebastien Cote
