How to set or grant Bentley Map users in Oracle Spatial do not include delete?
Hi Bentley Experts
We are setting up grants to our GIS users in database using Oracle spatial tables. The database admin grants the users including INSERT,SELECT and UPDATE. The activity is to have these 3 options only and not to include the DELETE option for the reason that, we don't want them to mistakenly delete some data in the map but during the post process, it turn out that the user can't able to post his work. The error message says that Delete grant is missing. Though this is true, the users activity is only to  INSERT and UPDATE the data, there is no such a DELETE activity during the process. Why is this happened? Is this normal with BMap in Oracle Spatial Editing? If not, How we will go about it and have these 3 grants options only work without then able to delete?
Thank you
Jun
