Hi.
Does Microstation support for WMTS? http://en.wikipedia.org/wiki/Web_Map_Tile_Service
I can get WMS to work, put not the WMTS.
-Stian
It is weird WMS server named Bentley Geo web publisher it has been weird for many years :)
Regarding the WMS caching in MS there seem to be issues with refreshing the view starting from SS3. It doesn't seem to be related to server as there are no issues in other WMS clients and also in v8i SS1 it works much better. See attached example(not from GWP server). Borders are not correctly shown when zooming in and out.
ST_WMS_robeza-EPSG3059.zip
The refresh problem you are mentioning is because the WMS server you are using seems very slow, so until we have the correct data from the server we are displaying the resolution of the data we already have, allowing the display to not freeze. If you want to go back to the old display just check out the Use Independent.... parameter below.
HTH,
Mathieu
