Connect Geodatabase
Jan Slegr
If I used national coordinate system (example: VN2000 UTM Zone 48N or WGS 1984 UTM Zone 48N), I can connect successfully to geodatabase. Unfortunately, when I used the local coordinate system (example: VungTau – VN – 2000) I don’t know why it couldn’t connect to geodatabase.
So far, I am using ArcGIS 10.2.2 and i don’t know exactly which version Bentley Map support for that.
I send to you file geodatabase. It content local coordinate system for that. Please verify it for me.
Sincerely!
From: Jan Slegr [mailto:bounce-Jan_Slegr@communities.bentley.com]
Sent: Monday, December 29, 2014 2:16 PM
To: GeospatialDesktop@communities.bentley.com
Subject: RE: [Geospatial Desktop Forum] Connect Geodatabase
/cfs-file/__key/communityserver-discussions-components-files/5924/3465.image001.png
Message from Bentley Communities
/cfs-file/__key/communityserver-discussions-components-files/5924/image002.jpg
Amy Nguyen
But I can't do it.
What does it mean?
Your question is like "My car doesn't go. I have Chrysler. Where is a problem?" As you can expect, it's not possible to answer such general question otherwise than also on a general level, which is usually not very valuable.
Please share more information and details, e.g.:
  • Is there any error message (dialog or in Message Center) displayed?
  • In what step the process doesn't work? During the connection definition or when features are queriedor in some different step?
  • What is a version of your geodatabase (in what ESRI product it was created)?
  • Is the problem specific for one particular geodatabase or to any you have tried?
  • etc...
With regards,
  Jan
View online
You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
http://communities.bentley.com/notification/read?NotificationId=5bbef62c-0d18-4db2-b70c-97f557254fb5
  • I also took a look at the file(s) . it seems as if there are 4 different feature sets in 3 different feature groups. Some polygons, linear, etc. These look fine in ArcMap. I suspect the Geographic coordinate system (GCS) has something to do with it. Have you migrated this GCS to Bentley Map ? What GCS do you have set in the drawing/model before you attempt to open the file geodatabase ?
    My suggestion would be to migrate this GCS to Map and try again. There are instructions on how to create a GCS from parameters.
    HTH
    Jerry
