Hi all,
I am setting up Text Style in Geospatial Administrator for the PBA but it seems my settings doesn't work. I noticed that this works in previous versions of BMSS3 but got this problem in BMSS4. I need your views on this.
Jun
Hi Jun, The TextStyle assignation works on my side on Bentley Map Ss4. It works for Text Feature and Text sub-Feature annotation. Is the TextStyle you set in GeoSpatial Administrator is defined in the working design file? Which TextStyle was set instead the expected one? These could be defined into the seed design file or DGN libraries (*.dgnlib) used. Is the MS_DGNLIBLIST configuration variable is properly defined in GSA? in DGN? Best Regards, Sebastien
