setting directory for Shape import
there was an old forum entry concerning exactly my question: why does the variable MS_GEOIMPORT_PATH not work? Using this variable, I tried to determine where my shapefiles and my .impx can be found, but this setting has no effect. I still have to navigate from some strange directory to my files. The forum answer was, that another variable defines the import directory: MS_GEOPROJHOME. I found that this is true, but changing this variable seems to be confusing for the system: my database is not opened automatically (like it was before). I have to undo the change, then my project is loaded correctly again.
Generally, I don't understand why there is a variable with a name sounding like exactly what I want, but it doesn't work. And there is really not much to be found in the Bentley Map documentation.
Any ideas? Thank you very much.
Regards, Uwe
Parents Reply Children
