Documentation lacks steps how to open "Conflict Inspector" dialog. How to use it?
From Help:
To work with Bentley Map in a versioned environment, Oracle´s Workspace Manager must be installed and the tables being edited must be version enabled. To perform conflict resolution using the Conflict Inspector dialog, the user needs to have the WM_ADMIN role granted. The user still has an option of working in a pessimistic mode when selecting a version. Doing so means the features must be locked before editing.
Hi Oto,
Please see attached example. I have not tried it in in the latest Map Enterprise version but I would expect it to be similar.
Let me know if it helps as I may need to try this workflow in the latest version.
RegardsCarlos
DOCX
Answer Verified By: Oto
