Hi Everyone,
I try to set property on feature like this
oFeature.SetProperty("PROPERTYNAME", Value); oFeature.ApplyAttributeChanges(); oFeature.Write(true);
everything is good but when i open Data Browser in Bentley the result is:
Unable to retrieve feature with id: 077a3eb5-53a7-44b7-9acd-06e4d54fd665
Thanks.
Greetings Nikolay,
Not sure if you've resolved this or not but I offer the following comments for others which may experience the same.
Jeff Bielefeld [Bentley]
Answer Verified By: Nikolay Tsonev
