For one of the users on same machine(Win8 English 64-bit ) the Mobile Publisher crashes with error "InvalidArgument=Value of '0' is not valid for index" on start. Previously there was decimal seperator set as comma "," in Windows settings and changed this to dot ".". Also tried to reinstall publisher and clean preferences using -restoredefaults switch but it didn't help. Where are settings for Map Publisher stored for user so we could reset it? If logged in from new user then it works ok.
Oto,
Does this issue still occur when using the following releases together?
Jeff Bielefeld [Bentley]
Tried this new version and it corrects the issue but now it doesn’t allow to set searchable attributes. Shows features in red. In previous versions it worked. (ST7000312857) Now there is also a new issue that special letters are lost in attributes on mobile device.
When selecting one or more searchable business properties you must use "Select Display Label" to indicate which property will be used as the primary label in search results. For example you may highlight the "Adreses_Mv" feature class then click on "Select Display Label" and choose the "ADRESE" property as the display label.
If you could provide us with a sample data set which illustrates the problem with special characters we can further investigate. We would need a sample design file and any Bentley Geospatial Administrator defined schema if applicable.
We are unable to publish any i-model or mobile imoldel on latest Map SS4. Any file crashes on multiple computers.
Publish: 0 succeeded, 1 failed, 0 up-to-date, 0 already published Error creating file: [C:\apmaciba\0_dabas_pamatne.dgn.i.dgn] Error protecting file: [C:\apmaciba\0_dabas_pamatne.dgn.i.dgn] Failed to encrypt file 'C:\apmaciba\0_dabas_pamatne.dgn.i.dgn' (error 8000) Encountered error from Bentley.Geospatial.XfmDgnECPlugin.XfmPersistenceStrategy. This PersistenceStrategy is being disabled during the publishing of the file: [0_dabas_pamatne.dgn] Publishing file: [C:\apmaciba\0_dabas_pamatne.dgn]
Do you run the application as admin ? I mean from the mouse right-click and then select the option "Run as Admin". As you know, this is not the same thing being admin on the machine.
Otherwise, it's perhaps link to the "activation level" of Bentley Map ?
http://communities.bentley.com/products/geospatial/desktop/w/geospatial_desktop__wiki/17145.bentley-map-keeps-starting-in-trial-mode
Let us if you can get any progress.
Sebastien Cote
