GIS Export makes MapInfo Tab files with coordinatsystem set to 'Local' instead of the GCS set in the model
Hi
When exporting Bentley map XFM features to MapInfo Tab files, the program set the coordinate system wrongly to 'local' if the model has the GCS set to System34 Sjælland.
If we instead exporting from model with GCS set to DKTM3 the coordinate system in the Tab file is correct!
Both names belongs the a Danish list og legal coordinates system in Denmark, and both coordinate systems resides inside the the standard library of coordinate systems that comes with Bentley Map.
Her is the list with the Danish Coordinate systems (Made by the BentleyUser.Dk)
And here the one can see the original setup in the Standard library.:
We believe that there somewhere in the configurations files there is a file defining the correlations between Bentley Maps GCS and the coordinate information in the Tab file (It looks like a lot of the GIS import/export functionality relay in GDAL dll's). So if anyone can point out that file and what to edit in that it would be a great help for us.
Thanks in advance
Erik Wirring
Landinspektørfirmaet LE34
Denmark
