We are trying to connect to a gdb in Bentley map Ss4 we are getting the error "Exception: FileGDB compression is not installed" With some GDBs we are getting the error immediately and others will connect and then during query we will receive the same error. The gdb were created using ESRI 10.1 I have ArcGIS 10.1 and can access these GDBs, there is not problem with them in it.
Any ideas or suggestions?
Sebastien Cote
