[Map SS4] Corrupt DGN level table after SHP import
I have issue that importing SHP data in Map SS3, SS4 the resulted DGN file is not correct. Features are correctly mapped but the levels they are on are not marked as used. If executing DGN repair by Key-in:"mdl load verifydgn;verifydgn repair" then it shows long list of errors like "verifyElm_hdr error: no level entry element found for level 1483". Also Map sometimes crashes when trying to close this file. The levels are from dgnlib and are not in seed file I start with.
Parents Reply Children
