I have issue that importing SHP data in Map SS3, SS4 the resulted DGN file is not correct. Features are correctly mapped but the levels they are on are not marked as used. If executing DGN repair by Key-in:"mdl load verifydgn;verifydgn repair" then it shows long list of errors like "verifyElm_hdr error: no level entry element found for level 1483". Also Map sometimes crashes when trying to close this file. The levels are from dgnlib and are not in seed file I start with.
Sebastien Cote
The problem is simple. Bentley Map does not import levels if they are linked from DGNLIB. This is not normal behavior as normally in Microstation if I set a dgnlib level as active and draw new elements using drawing tools then the level is automatically added to active DGN file level table and marked as used. The level number you see comes from autonumbering(CAPABILITY_LEVELS_USE_AUTO_GENERATED_NUMBERS) . If I import levels from dgnlib using Microstation(because there is another issue if importing in Map) then the import works ok. Also see that only level with name 1000000001 imports correctly because it is not defined in DGNLIB and so doesn't make a conflict.
