Hello.
I'm having problems installing the latest release Bentley Map Mobile Publisher (version 05.02.01.16). I'm running Bentley Map (08.11.09.83) for Microstation and every time I run BMMP Setup a window pops with the following text:
One of the following Bentley products must be installed:
Since I have Bentley Map 08.11.09.503 installed I don't understand why this message pops-up.
Any solutions?
Regards, Bjorn M Arnason
Bjorn,
Is your Bentley Map V8i (SELECTseries 4) 08.11.09.503 installation the standalone or layered for MicroStation edition?
Jeff Bielefeld [Bentley]
In your original post you state "I'm running Bentley Map (08.11.09.83) for MicroStation" so this is not the case? To be clear, you only have a single Bentley Map installation, specifically Bentley Map V8i (SELECTseries 4) 08.11.09.503 layered for MicroStation, correct?
