I am extracting a point feature from ArcGIS, using the Bentley Geospatial Administrator. I have told it the level, symbology, cell to use, field to use for Cell Angle, and the location of the cell library. It finds the library, uses the correct cell, places it at the size I asked for and on the correct level. However, it never uses the Cell Angle field; it always places at 0.
The CellAngle field I have chosen does have nulls in it. Does this make any difference? I've also noticed that some of these angle fields in ArcGIS are double, and some are string. Does that matter?
Jeff Bielefeld [Bentley]
