Hello!
Recently I'm trying to convert a Bulgarian coordinate system 1970 to UTM, and i struggling whit it. I can find many points from CS (coordinate system) 1970 and their UTM coordinates from different CS converting programs.
I find this on the topic:
file:///C:/Users/Valeri/Downloads/2D%20Conformal%20Transformation-rev1.pdf but it seems so complicated.
I activated Bentley map in my Power Rail Track instance (i hope there is no extra charges :S ), but i still cant edit the GCS (geographic coordinate system)
And i find i can warp the file:
How can i use it?
What must contain the *.ctl file?
Is this i looking for?
I finde in GCS a system that is closest to ours:
but the latitude is from 43°37'12.0000"N to 48°15'36.0000"N, and its for Romania only. I need it from 41° to 45°
Can someone explain step by step how to procedure it please.
A. Mateev
The steps required to edit a Geographic Coordinate System are show in the Slides at:
http://communities.bentley.com/products/geospatial/desktop/m/geospatial_desktop_gallery/218386
Thank you!
I managed to create a editable coordinate system.
Now it looks it comes hard part... The Bulgarian 1970 coordinate system is very old and "stinky"... Very little people know how to convert from it. And I don't know the correct parameters. If someone know how to find correct parameters it will be great.
This is the information that I know about the Bulgarian 1970 coordinate system. If someone knows other information that he may need to help me I will try to find it.
"A type of projected coordinate system from the conical projections class. Four types of Lambert zones are defined under the coordinate system. Each of the zones is determined by a preset origin, by the reference latitude scale and by the range of F. The maps’ grid reference system is the 1970 Coordinate System. The four existing zones are: Đš - 3 (North-west), Đš - 7 (North-east), Đš - 9 (South-west) and Đš - 5 (South-east). Each of the zones is part of the Lambert coordinate system, i. e. its planar part is rotated to match map’s north, at a relatively small, but zone specific angle, selected in such a way as to preserve map’s conformance.Constants specific to each zone are added to the to the planar coordinates, so that the final coordinates’ format is Gaussian. The real coordinate values are Y=8 500 000 m и ĐĄ=4 500 000 m."
www.google.bg/.../@42.7104605,25.5902966,8z
It uses Ellipsoid [KRASSOVSKY 1940]
I can provide points transformed from 1970 from all zones converted to WGS84 N34 and WGS84 N35 if it will be in help.
Did someone know which are the correct parameters ?
(BRT V08.11.07.685, on MS, SS 2)
You may have to build your Custom Coordinate System from Placemarks using the MicroStation tools for that. This PDF document provided by the ASPRS indicates that...
In the 1960s it was decided to use
the “System 50” only for military applications
and to introduce a set of plane
coordinates for civilian use. The new system
consists of four Lambert Conformal
Conic projections on the Krassovsky
1940 ellipsoid; the four overlapping
zones are K3, K7, K5, and K9. Each zone
is defined with a latitude of origin and a
scale factor at origin, and each zone has
a different initial azimuth of the central
meridian in order to rotate (and obfuscate)
the grid. The parameters remain
secret to this day, and this practice (including
zone rotation) is typical of many
of the former Soviet Bloc countries.
Here are some online Bentley Communities remarks and references for Placemarks:
How to define a custom projection?
Geocoordinate Systems, back to Placemarks?
otherwise use the MicroStation HELP instructions under Setting Up Projects | Geo-Coordination.
Hi again!
I menage to create GCS by place marks and re project to WGS.
In the text files you can see the Placemarks-70.txt file are my 1970 CS points. In Placemarks_trWGS.txt are points converted from a converting program.
My placemark set looks like this:
And the placemark 2 is in far left.
As you can see in the GCS from Placemarks dialog box, there is some error:
That means the program did not create the correct GCS (1970) but some close to it... (i think the program did not recognize the placemarks as Lambert Conformal Conic projection)
Is there a chance to make exactly the 1970 GCS by placemarks ?
