I am using MicroStation V8i 08.11.09.608. I recently updated the linework in a DGN file and referenced it into another DGN file. For some reason, it identifies the reference file elements as XFM features, which they are not. The elements in the referenced file were not created using Bentley Map and when I open the original DGN file, they are identified as MicroStation elements. Why are these elements changing from a MicroStation element to an XFM feature? Is there some setting somewhere I'm not aware of that I need to change? I have several other files referenced and none of them have this issue.
Sebastien Cote
What is the shortcut you run ? Or how you open your working session ? What is the workspace user loaded ?
